For general Windchill Part, if you select it in left structure , its representation will be highlighted in the right
Cables cannot be displayed in Windchill Visualization tab(Process_plan.png) as in Creo View(CreoView.png)
The Cable doesn’t have its own content file and Representation
The requirement is to be able to select cables in the left structure similar to general Windchill part.
NOTE: PTC case C15989846 which has details about this requirement.
