Post Publish rule for setting the GDD revision
For a Post Publish configuration, provide a Post Publish rule option for the Graphics Dynamic Document’s (GDD) revision to match the associated Creo Parametric object’s revision. This will help indicate whether a GDD is out-of-date with the associated Creo Parametric object. Out-of-the-box, this is not supported. This will allow for greater control over the publishing and republishing.
2 Comments
jbailey
This would also be useful for secondary pdf/step/ etc  documents that are created from a visualization.
Phil_Molstad
I agree. In our environment, the CAD Document and additional files (WTDocument) are controlled documents and revised together.  Therefore, it would be extremely helpful if the post-publish process identified and iterated the latest, revised WTDocument.
CS216668
