Post Publishing rules for republishing upon the detection of an associated GDD
For a Post Publish configuration for creating the Graphics Dynamic Document (GDD) by a manual Post Publish method (publish on="manual-post" param-set="Publish GDD"), provide a Post Publish rule option to republish the GDD on a State Change (publish on="unknown-source") or Checkin (publish on="checkin") upon the detection of an associated GDD to the Creo Parametric object. Out-of-the-box, this is not supported. This will allow for greater control over the republishing.
Current Options:
  • Configuring the Post Publishing with non-manual-post rules: This will create many unnecessary GDD’s.
  • Configuring the Post Publishing with manual-post rule: This requires the Creo Parametric user or Creo Illustrate user to manually Post Publish every time the Creo Parametric object is modified, which can be easily missed.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
