Without having each users at site to manually select the 'Create and Auto associate Part' option while creating an EPMDocument (MCAD or ECAD) via Windchill workspace UI, it would be nice to have a preference that controls the feature that can be controlled at the site level.
Use case is : User logs into Windchill, navigates to the workspace and creates a new CAD Document using the 'New CAD Document' wizard. There is a check box that says 'Create and Associate Part' in the first step of the wizard.
If the preference is set, the checkbox would be selected by default and then a WTPart automatically gets created when a user creates an EPMDocument.
