When you modify a promotion object in a running promotion request you will lose the promotion comment for the modified object created initially
Use Case:
1: create promotion request (PR) with promotion comment on promotion object
2: send PR to rework
3: rework promotion object (new iteration)
4: send PR to approver
4: promotion comment is missing on promotion object in PR
It should be possible to keep the promotion comment of promotion objects as it will be lost completely.
