Hi
Need a feature to warn or block if a part is added to an ECN if it´s already part of an active ECN. This to prevent parallell changes.
Example: part 1234 revision A is added to one ECN and revised to part 1234 revision B. Now a user add part 1234 revision B to an ECN and revised to C. C will be a copy of B in that moment. Changes are now done at both B and C. When the ECN´s/Parts are released revision C will not contain changes done in version B. To support this use case, Windchill need to support branching/merging (as Pro/Intralink 3.4).
To prevent users to run in to this issue, Windchill shall warn/block if a part is added as affected item.
