Prevent deletion of global attributes, because it leads to database inconsistencies
In PDMLink it is possible to delete global attributes, but this leads to inconsistencies in the database. As a result the download of family tables fails. PDMLink reports: Server error: Cannot retrieve family table neutral data.
The following steps lead to the error:
  1. create a global attribute and map it to a Creo parameter
  2. edit a family table in Creo and add the parameter
  3. check in the family table
  4. delete the global attribute
  5. download the family table -> Server error: Cannot retrieve family table neutral data
We suggest to remove the delete-funktion for global attributes or to handle deletig of global attributes correctly in the database.
3 Comments
Marco_Tosin
Undine,
you have to vote up your idea.
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
