Currently when browsing Context folders or Search Results tables where the Thumbnail Navigation column is displayed, you can hover your mouse over the thumbnail and the visualization popup will occur. Just by hovering over the thumbnails your Recently Accessed, Recently Visited, Recent Products and Recent Libraries lists all update with the object(s) you hover over. This will "clear" your lists of actual desired content especially if you advertently or inadvertently hover over many of the thumbnails. It seems that the Recent Lists should only update when you visit the actual Information/Details page of an object or context. I would like to see that functionality change so that hovering over thumbnails does not update the Recent lists.
