Hola,
we are often facing situation when via change task releasing dozens of objects but not all of them having the same LC state. I mean situation when all objects been revised to "In work" state but:
30 objects have release target "State 2"
50 objects have release target "State 3"
10 objects have release target "State 4"
40 objects have release target "State 5"
It is very complicated and time-consuming to sort out all objects in change task and set up proper state for each group of objects. We would like to have an option "Previous revision".
This function will automatically set up the same state like it was in previous revision. It would work like in a case when object has been revised from "State 3" => "In work" so function will set up again "State 3".
Using this option when all objects preselected can send them back to the same states without manual selecting.
