Add the ability (without Cognos) for a user to print Change Documents. We have a need to print these documents and it blows my mind that I will need to have a custom code written to PRINT. We will not use Cognos until a later version is supported that also supports SQL 2008 R2. Why is it that the simplest of things (printing) becomes a complete nightmare and cost companies SO much money. I have a meeting tomorrow to present the numbers for a custom printing solution....I can't wait to see the look on the executives faces when I tell them this is needed to print.
Note: adding another server and SQL license to run Cognos is not desired by IT here.
