Resources allocated with operations in a Process Plan will become default hide if an operation is open Default Representation in play back mode. See attached PowerPoint.
it is NOT working as expected from a user point of view.
What you see in Windchill Playback should also be visible ( without need to use show action in Creo View for default hidden objects ) default in Creo View.
When it is NOT direct show the same visualization in Creo View as in Windchill, it become very confusing for the users.
For users this is a bug but for PTC this is an enhancement so therefore we need to follow the administration and create this Product Idea so PTC could file an SPR to it.
