Issue 324 - Process Plan - Show BOM Usage Expression for parts also in Process Plan Structure - not only in tree picker.
One way is to show in the same column as Process Plan Assigned Usage Expressions or to be able to add a separate column for BOM Assigned Usage Expressions.
Much more user understanding if this information is shown in Process Plan structure.
See attached picture.
