Process Plan - show BOM occurrences allow re-allocate BOM occurrences in Process Plan structure.
Process Plan - show BOM occurrences in structure and allow re-allocate BOM occurrences directly in Process Plan structure.
As-Is: BOM occurrences only shown in Tree picker.
Re-allocate in Process Plan structure is only possible for BOM usage.
To-Be: BOM occurrences should also be possible to show in Process Plan structure
Re-allocate BOM occurrences should also be possible like BOM usage is today.
6 Comments
Aquamarine
I guess this idea has duplicity with
Is it possible to view the process plan structure in occurrence mode?
I would suggest to merge the Voting
Best Regards
Regular Member
No, this is two different ideas. Show occurrences is not the very same as allowed to restructure occurrences directly in Process Plan.
BR,
Åke W
Aquamarine
Almost same. Edit occurrences needs to show them. So from my view it is same.  if you can show them you should be able to edit them in structure.
Best Regards
PetrH
Regular Member
Then we can just hope PTC will fix this in near future Smiley Happy
Regular Member
He he,
From a PTC developers point of view this is two completely differne things.
To show occurrences is quite easy,
to manage restructure of occurrences in Process Plan structure is a little bit tricky to develope.
Åke
Aquamarine
If you read the use case of second idea carefully You will find that the useCase mentions move option of occurrences instead of removing them.
So in my opinion one of the idea is duplicated.
