Removing attributes by hiding them in the create and edit layout is a great feature
It is helpful to reduce the clutter and to guide the users.
However it might be required that a data management or administrator maintains these attributes or need to fix some values
For this it would be great to use a profile to make these attributes editable again in general.
While the visibility works on the different types independently and provides greater granularity the profiles just work on the gobal iba itself.
Today profiles are overruled by the type definition in any case not by the highest visibility rating like "EDIT"
