Привет!
nowadays in WCH 10.2 when a new promotion request is created at step 2 "Select Promotion Objects" have to:
Setting object is redundant. Also unable to select different targets for each object (all objects must have the same target = useless).
I suggest to unify layout with change notice (add also icon for multi select target and allow to manage it faster). Then just need to:
