In wtparts we can use 'replace with existing/new/alternate/substitute' and 'supersede with existing/new' and in Creo CAD we can also replace components in an assembly. But these replacements that happen in CAD are not carried over to wtparts and thus cannot be easily seen in structure view.
So this Idea is to propose to propagate this 'replacement' information from CAD to wtparts when building them after checkin.
This would solve and make visible all those cases where a replacement was done but initiated from the CAD side which often happens in agile organizations.
