PTC should provide a way to implement customized structure filters for the product structure explorer.
Within the code it is quite simple to create a different strategy to walk through the productstructure --- The problem is that currently ther is no way to hook this into the user interface.
For example we have cases where we use the effectivity to navigate down the structure but the standard doesn't fit to our needs.
