When publish drawings via PDMLink using a Creo Worker with Creo View Adapter the chooises are limited for what will be plotted out to the published drawing.
In other words if you in your drawing using a extra BOM-tabel or anything else outside the format paper outline this will also be visible on the published drawing. If the drawing is printed/exported from Creo this is a option to for example only plot paper outline. This is the difference and therefor it whould be a functionallity needed for the Creo View adapter aswell.
This is a functionallity that is not there today, reference at PTC TS: C11564032 / SPR219673
