Published neutral formats (PDF, DXF, IDX) are missing in tab "Viewables" of CreoView
The PDMLink publish process can create file formats like PDF, DXF or IDX. This files are added to the representation. But after opening the representation in CreoView, CreoView does not list the neutral files in the table of "Viewables", because the publish process does not update the PVS file.
Workarround to visualize the neutral formats in a common CreoView session: the user has to save the representation and move the files via drag and drop into the graphic window of CreoView to enable the selection of the neutral files.
Proposal: The PVS file should be updated by the Windchill publish process
  -  either in general for all visualizable file types
  -  or dependent on a new preference in which the formats can be listed
2 Comments
bli
2-Guest
2-Guest
good proposal
jean-claude
2-Guest
good proposal
