Publishing of non-persisted attributes
PTC customers have presented use cases requiring Alias and / or Server Calculated attributes be published as part of Serial xml output (via SIS worker).
Suggested enhancement
Provide OOTB capability to include Alias and Server Calculated attribute values in the serial xml output. (e.g. for inclusion in PDF and other published output).
Example Configuration / operation
Use existing publishableAttset and translateableAttset.xml files to determine which attributes are included in this mechanism
  1. publishableAttset will determine attributes requiring "Display Values" in the serial xml output.
  2. translateableAttset will trigger routing of external enumerated attributes through the "Dictionary Translation Process"
          2.a. Attributes will have a paired "translateable attribute" in type manager.
          2.b Attributes will utilize standard xlif translation process.
          2.c Attributes will use Dictionary values in Serial XML published output. (Instead of the locale value stored on the enumeration itself)
1 Comment
olivierlp
Community Manager
Status changed to: Archived
