Include the ability to “lock” an RBD Diagram protects the Graphical layout of the RBD; The same capability should be extended to protect the properties of each block and connector. The ability to set an RBD Diagram in its entirety to “Read Only”.
Rational: When working in a team it is logical to share the effort of building the diagrams to different users specializing on different areas of the product. Each user would be responsible for their own Diagrams and a method of configuration control is required to ensure accurate results and team responsibility. The expectation of good embedded configuration control practice is elevated when WQS is deployed alongside Windchill PLM.
