RBD Module; Cut Set Results
Generate Calculation Results for “Unavailability” with cut sets while using Monte Carlo simulation.
Rational: Certain Diagrams force the need for Monte Carlo simulation method to be used both for consistence of result format and sometimes diagram complexity. The cut set function allows us to determine the contributing elements in our system to focus upon based on potential weakness. Without a measure of the Unavailability we lose the guidance on what problem areas to address.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
