The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
RELEX RBD: group feature
0 Kudos
If I try to change some similar parts' failure rate or mttr, I need to open block one by one and change it. can you make a "group" feature (not dependancy group), that let user to change same property values for all parts in this group?
2 Comments
rthomas-2
2-Guest
Jiali,
here is a workaround:
In the RBD blocks table, make sure that failure rate, mttr, etc. data fields are displayed. If you don't see them, activate them by using the format builder (right click / format builder). This will enable direct data input.
Use sorting and filtering for more convenience.
Thomas
PTCModerator
Emeritus
Status changed to: Archived
