The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
RELEX RBD: the best way to model a UPS standby battery in RBD
0 Kudos
I've been told to use the battery maintenance to mimic the battery operating.However, the battery shows very high "downtime" after calculation. That because when putting 10-min operating into Maintenance with 3-hr recharging time as restoration, the RELEX treats 3-hr as downtime and must be completed when started this maintenance. In reality, if the battery is just used for 2-min, don't need 3-hr to fully recharge it. so "downtime" caused by this type of maintenance is exaggerated. Secondly, if I put "0" for restoration for this maintenance, then during simulation, RELEX will miss the case that battery can only last 10-min, in the event log, I see the battry "start-stop-start-stop" repeated for couple times.
Is this a bug from RBD? or I didn't model it correctly?
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
