Re-Entering a complex material into the BOM because of changing the T2
0 Kudos
Defect description: When re-entering a complex material in the BOM because of changing the T2, the old levels are not deleted, but the new once are added in between.
When save and check in the “old” levels get deleted. Can they be deleted at once.
User Role: Creation Center Developer / Saskja Stinzing
Expected behavior: Not add the new levels in between but overwrite the previously entered levels.
Actual behavior: New levels are added in between and the old levels only go away with "Save & Check In".
orkaround / TS Comment: Both the issues occur when we are replacing the existing complex material. So we can use easy workaround to add a complex material in a new row and delete the earlier row to overcome this. We understand that these are the issues however we have an easy workaround to overcome this. Also is not impacting the functionality when you are adding the complex material for the first time hence it looks like it does not have much impact as we can delete that row and add a new row than replacing the complex material.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
