Re-add Quantity Options to Uses Tab in Part Structure That Allows for Strings
0 Kudos
In EPDM 10.2, the user could add the Quantity Options attribute to the Uses tab of the part structure page.  In the Quantity Options cell, the user could then select a string value, either AR or ALT.  With the 11.0 upgrade, that function only allowed for an integer in that cell.  I'd like to see the previous functionality restored.
4 Comments
JeffZemsky
Status changed to: Current Functionality
This is supported with the 11.1 F000 release that moved the Parameters and Constraints functionality to PSB from PSE.  This should also work in 11.0 - but I don't have an image on hand to validate
JeffZemsky
mluberti
I tested this out on Windchill 11.0 M030, and it's not working like that on my end.  When I type the desired value, either AR or ALT in the Quantity Options cell, I get an error stating that the quantity option specified is invalid.
JeffZemsky
In 11.0 M030 you might still have to do this in PSE versus PSB.  If it is not working in PSE please raise a call.
