Buongiorno,
when lifecycle (LC) is reassigned then workflow running over this object is terminated without a notice.
It is very annoying and time consuming to realize running workflow is been killed and have to run it again manually. Sometimes it can affect hundreds of documents etc.
We need to at least be noticed that this is going to happen or have some workaround how to keep workflow alive...
