The new REACh rules/guidance requires some changes in the data exchanges between companies. Below are the main changes that I've identified :
- The SVHC must be located. In a complex part (with several articles), we must know where the SVHC are present at > 0.1%.
- The safe conditions of use must be communicated. For each couple SVHC-location we must have the ability to attach a text that will be communicated to the end users.
- The mass of the article or products are no longer required, as well as the SVHC concentrations.
=> In addition to the redesign of the REACh report, new fields must be added in the database, and the upload tools must be modified in accordance.
I hope this description will help defining the WPA evolutions that we need in keeping environmental compliant and friendly !
Pierre.
