A common use case for Weatherford is the need to associate/link an EPMDocument to a WTPart using a Referenced By link, exactly like the Reference By link already available between a WTPart and a WTDocument. So that the WTPart is linked to the EPMDocument master, so it is not a requirement to revise/maintain the relationship to a specific version of the EPMDocument. This would allow the Reference By linked EPMDocument to be revised independent of the WTPart.
For Weatherford there are two main use cases for this:
Often these EPMDocuments are applicable to multiple assemblies and are maintained by someone other than who maintains the WTPart, usually with mutually exclusive permissions.
E.G. An Engineer maintains the WTPart and doesn’t want a technical writer to have access to change it. A technical writer maintains the EPMDocument and doesn’t want someone in Engineering to be able to modify it.
At previous technical committee meetings these were common requirements for a number of customers. I know it is possible to do something with a configurable link, but I feel this should be available out of the box.
