When you start an action / function / wizard on an object, but you have opened several tabs/windows and you switch in the meantime to some other tabs/windows, you don´t know anymore to which object the opened action / function / wizard blongs to.
Please add the number/relation of/to the related object into the wizards.
Here an example for the Edit Multiple Parts wizard:
