Add ‘conditional’ feature to calculator tool. For example; in the ‘calculation editor’ this should be valid:
IF CALCULATION MODEL = PRISM THEN User Value 1 = [Failure Rate, Predicted (System Tree Configuration)]* 10.0 ELSE…………...
This allows calculations to distinguish between, say, MIL 217 models and PRISM models and apply or not apply a calculation rule.
