Remove Share from Project with collector window
While doing an Unshare or Remove Share of and Assembly or Drawing from a ProjectLink Project it should show the dependency collector Window. This helps to unshare all related parts of an specific ASM or DRW.
2 Comments
sm
1-Newbie
1-Newbie
Excellent idea. Related models and drawings can be in any folder of the project and picking through them one-by-one is not an effective way of removing shared objects. You may also want to ask for the ability to "Remove Shares" for multiple objects from the Search Results table. Its easy to create a quick container search for all parts, epm.docs and wt.docs in a project, sort them by status and then select the group. However, the "remove shares" action only supports single row items, not multi-select. Seems like something easy to add...
PTCModerator
Emeritus
Status changed to: Archived
