The use case is:
I have a list of 500 items where I need to perform a mass change. I modified the list to be separated by semicolons ; so that I could input that in to a search field and add them to Windchill clipboard so that I could finally paste them to an ECN.
When I tried to paste the list to the number field in Windchill search, an error message tells me that only 1000 characters are allowed. This will only give me about 60 out of the 500 parts. So the character limit should be more like 10 000.
Solution: Remove or raise the character limit in search fields such as: keyword, number, name...
