Current behavior is described in CS37461.
But customer desires to change object's name by some dedicated permisson like 'RENAME' not depending on 'MODIFY'
because the object once released turned to be read-only(cannot MODIFY), if the object revised, nobody cannot rename though the object status is still 'In-Work'.(because Rev.A is read-only; cannot MODIFY)
