Implement a preference that enables to specific the default setting for Rename as FileName same as Number.
Such a preference is available for SaveAs, but not for Rename (?!?).
We are implementing a Windchill system in which the Number and the FileName have the same value.
Having this preference is much more efficient as by default the FileName field does not needs to be filled out, FileName will get the same as Number.
Please note that there is an option during Rename to manually specific FileName same as Number, but it is not the default and we cannot specifiy it as default as there is no setting or preference.
