Rename notification in workspace
I have run into an issue where a CAD object was renamed in the commonspace while it was in my workspace, and I was not aware.  I wasn't able to upload or check-in my work, getting the standard cryptic error message "Wt.properties error....blah blah".  After I discovered the object had been renamed (had to ask around and dig a bit), I was able to synchronize the workspace and check-in without issue.  A notification in the "Commonspace Status" column could have saved me this grief and time.
3 Comments
dhermosillo
I agree.  The notifications for metadata such as rename, move, etc. are woefully inadequate.
STEVEG
It tells you in the Compart Status column if the File Name changed after a refresh of the workspace.  We always keep our Number equal to the File Name.  But I agree it would be nice if it informed you of more than just the File Name differences.
PTCModerator
Emeritus
Status changed to: Archived
