Replacing a WTPart in Windchill and publishing to CAD after Check In does not work. The new Creo component is not assembled in the Creo assembly. (If the replaced part has no children it works)
Using Creo to replace the component works fine. But if you want to replace one component / part in several assemblies during mass Change and incl. mBOM it is not workable to use Creo.
Link to PTC Case: PTC Case 14667208
Attached find the full documentation.
