Replace new introduced X-Icon on step 2 of the import to worksapce step with common used function
The newly introduced X-Icon in step 2 of the import to Workspace should be replaced by the common used icon's to exclude, include or remove icons. Since the intended function is not obvious to the users.
With PDMLink 11.0 M30 a new x-icon was introduced by PTC in the import to workspace step 2, to remove the OOTB strikethrough for DIFFERENT_VERSION and CONFLICTING VERSION objects.
See CS301330.
The user has the feeling, that he cannot import the objects with a strikethrough although he could use the X-icon. Since the user assumes that the x-icon would remove the object from the list.
Instead it just removes the strikethrough. Which is normally done by other icons (e.g. see add to Workspace GUI).
Please replace the X-icon in the import to Workspace dialoge with the three icons marked in the add to Workspace picture.
2 Comments
jzimmermann-2
3-Visitor
Yes, this is really important! The same icons should be used for the identical actions in Windchill.
olivierlp
Community Manager
Status changed to: Archived
