The reference of the solidworks drawing shows the older versions which is not desirable , even though the End user changed all the references in the physical Solidworks drawing. Also as per the rule,Calculated link cannot be broken manually using edit associations, it should be created by itself from the relation of 3d object and Solidworks Drawing.
Windchill version 11,1 M020 CPS07.
