Reset attribute values during "save as" & revise
In a state of the art PLM system you want to keep the data quality as high as possible.
You enfore the users to fill out required attributes, to follow special formatting rules etc.
But it is common that values which got entered for a source object are not any longer valid for a copy of it.
And even for a new revision of the same object some attributes might not be valid anymore.
Windchill should support such a configuration OOTB by preference seetings which specifies
Attributes to be reset on "Save As" = IBA1, IBA2, Master IBA4, not sure about MBA3 - modeled but would be superb to support all kinds of attributes
Attributes to be reset on "Revise" = IBA1, IBA2 - in my opinion it would be sufficient to support just IBAs
Attribute Reset value on "Save As" = Default, Remove
Attribute Reset value on "Revise" = Default, Remove
Default will set the Default defined in the type manager
Remove will remove the value after revise/copy and will enforce new data entry again for required attributes
12 Comments
Amethyst
Oliver,
nice idea
we've got exactly this need, and today handle it by customization in a listener..
with some limitations, cause notably for attributes with a required constraint that we "remove" on save as
the enforcement is only controlled in the next checkin ....
regards
Pearl
I just voted again for this idea. Hope this is finally coming in Windchill 11!?! The user are requesting this feature since ever...
Pleas see also the similar ideas to this:
remove attribute value during revise or save as
during save as it should be possible to change additional attributes
Modify custom attributes while doing a "Save As"of an object
Perhaps there are even more ideas around.
(I would already be happy, if you just could add some attributes to the list and edit it...This would be the deluxe version)
Marble
Supporting manual attribute modification during revise & save as wizard would be another request.
Björn you are fully right, this would be very nice enhancement since the values can have impact on numbering rules as well.
It is also horrible to customize.
Garnet
Hello Gregory. Which listener? Is there an Event class that manages "Save as" event?
Marble
You can listen for the save as history which throws the create event. After that you can wipe out the attributes
Garnet
Hello Oliver, thanks for you suggestion but...what about EnterpriseServiceEvent.POST_COPY ?
I found it this morning and it seems exactly what I'm searching.
Anyone used it?
Visitor
Hi Nicola,
Did you try using EnterpriseServiceEvent.POST_COPY?
I tried and have not had success with it.
Thanks and Regards
Midhun Mathew
Garnet
Hello Midhun, why?
I'm now using it with satisfaction.
Visitor
Hi Nicola,
I had a typo issue with the code. And it works now for me as well. Thank you
Midhun
Community Manager
Status changed to: Under Consideration
Regular Member
hi All
Exactly the business case we have.
@ngiacom, @mmathew:
Do you have a documentation for that EnterpriseServiceEvent.POST_COPY?
I can not find anything in the Knowledge Base.
I am grateful for any information or help
Best regards!
Daniel
Garnet
Hello Daniel, I don't have documentation, I'm sorry, you probably have to ask to ptc.
