Case 12585563.
In 10.1 CounterPart had functionality to add custom IBA as classification attribute in the result table and in the refine search.
In 10.2 CounterPart was integrated in Windchill UI but there are many side effects.
The most important is the slowness introduced but an other issue is that search result is not filterable for custom attributes.
