Result table of a detailed Search should contain the criteria i searched for
Execute a detailed search with a criteria IBA called 'article number' = 12345. In the result table there is no such Column like 'Article Number'. Why not?
Every time you make a new search you have to look if there is an defined View, if you dont find one, you have to create it. At the moment you have to customize a view for every possible search or result to show the result in a way the user unterstand it. You can save time and administrative overhead to create Views!
15 Comments
Brasseler
3-Visitor
Shure it would be nice to get the attributes you searched for in the result automaticly.
But the point of the matter is, rigth now you are not able to define a view with that attributes inside, whatever way you choose!
dkolloff
3-Visitor
You are right, especially if you have this IBA on WTPart and EPMDoc, your List of Attributes within the view definition does not show theese Attributes...
MorganBelais
Having the searched attributes automatically displayed when searching for it will be a huge benefit in productivity.
Today you almost have to create a new view each time you are doing a new "kind" of search and the views available in the list is increasing, becoming almost unusable.
DiviLohiya
1-Newbie
This is something which PTC has on its roadmap and is being planned for upcoming release. Infact, it was included in the mock up evaluated in the UX lab. Users found lot of value when attribute searched on was multi value (with OR) or used wildcards.  When the attribute on which search was based had exact value, it served as validation of the search result.
BenPerry
Divi Lohiya‌, can this be moved to IMPLEMENTATION IN PROGRESS status?
BenPerry
Vikram Sinha‌, can you please update the status of this product idea?  I believe Windchill 11.0 covers this.
Vikram_Sinha
That is correct. We have introduced the dynamic columns feature in 11.0, so the criteria selected on the search query builder will be displayed as a column on the search results table.
PS: This would be in addition to the already set table view columns.
BenPerry
But Vikram Sinha‌, can you please update the status of the idea to "Current Functionality"?
Vikram_Sinha
Ben Perry‌ Can you please direct me how to do that? I am not able to find the status field on this page.
cschindler
3-Visitor
The idea Add criteria to search display result goes in the same way and has been move in Implementation in progress.
Could you please also update it.
CaitlinWheeless
1-Newbie
Ryan Kelley‌ should be able to help with that.
Ryan - Vikram is the product manager for search. Can you verify that he has access to update product idea status?
ryankelley
1-Newbie
Vikram Sinha‌ - I've added the correct permissions to your account. You should be able to edit this Product Idea and update the stage to "Current Functionality". Send me a direct message if you have any questions about the process.
Vikram_Sinha
Thanks Ryan Kelley‌ and Caitlin Wheeless
Ben Perry‌, I have updated the status of this idea to "Current Functionality"
Vikram_Sinha
Done. Updated it to "Current Functionality"
PTCModerator
Emeritus
Status changed to: Current Functionality
