Resulting Object Target List Default
Resulting Object Target List Default:
Current behavior is the Change Activity Wizard defaults to the Change Transition;
Product Idea:
Require Users to make a Selection;
Allow the Default for the Target to be "Blank" or "Select from List" and Have Requirement for User to select a Valid Transition.
Or Let us Select what the Defautl Transition shoul be that is visible.
Current Default Behavior:
For a Lifecycle State Scheme Ex:  Inwork-PreReleased-Released-Obsolete-UnderReview
Requires you set the Default Transition "Change" to go to PreReleased;
And use the New "Production Released to go to Released.
This is general work-around;  If You are a LongStanding Customer who has been using "Change" Transitionf for Change Process to go to "Released" then you are at Risk of Data getting Released (ERP Connector also sending to MRP)
IE
Greater Flexibiilty for New Multi Target would be Great.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
