Servus,
for every duplicated operation in MPMLink is strictly generated unique number. Our users not happy with this behavior much.
Very often we need to duplicate just a few operations from one process plan to the another one and keep the content unchanged. WCH always duplicating all operations under new numbers even everything is the same. It means database is growing up even no reason and users have to handle for example 10x the same operations+documents.
Would be nice to have an option for keeping the same operation number and let users decide if they want to create a new operation with unique ID or just reuse existing one. We see a great advantage to have 1 operation valid for 10 process planes instead of maintaining 10 the same operations...
