In ProjectLink there is no capabilities to revise wtDocuments.
We have scenarios that partners use only project to collaboration information, with no access to Product and Library and it is necessary to create, edit and revise documents.
It is possible to use PDMLink to use the send to PDM, revise the document and after share to project, but it is a lot of steps to revise one document with no value.
