Revise files from the Advanced Search results
Why isn't the revise command available when boxes are checked to multiple files in the search results,  I know when the boxes are not checked, you can right click on one the files and revise command is available.
I am suggesting that the revise command made available when selecting multiple files either being CAD, wtpart, documents, etc.
Just like in the change task of change notice where you can search for all the files being CAD files, wtparts, documents, etc., then you can select all and revise all of them at same time from the affected objects field into the resulting objects field.
