Can we expand the capabilities of the documents accessed in DTI for Projects be able to Route for Approval and Review processes?
Since the introduction of the DTI, project teams find it easier to use this feature most of the time. Once installed, basic operations such as Checkout, Edit and Checking can be performed.
Only missing key feature in projects is routing of the document for Approval or Review process. We also use Notify process. So, if Routing option can be enabled in DTI, the usage of the tool can be more effective.
