As more organizations move toward DevOps and continuous delivery / integration, automated install capability is a must. While Solr is open source, PTC has created a custom wrapper around it which is required for configuration and operation. Per C14188537, PTC currently does not support any form of automating Solr PSI install. Similar to how PTC has already started using the response file concept to automate the CPS installs in https://www.ptc.com/en/support/article?n=CS250208, this idea request to extend the effort to support automated installs for Solr.
