SOLVED: Manage Arbortext Customizations with Windchill
Hello!
we were able to solve our requirements with the Annonymous Arbortext Access in Windchill. From our point of view, this is ok and it is not necessary to follow up this idea.
your Windchill Team @ DATACOPY
When having customization and/or custom applications for Arbortext Editor, we need to deploy them to every user (when not using a compact-installation).
However, we'd like to put the customizations (\custom folder) and the applications (s.th. that is read as application by AE) on one place in Windchill, so that the Arbortext Editor authors could use this.
Maybe this could be realized as an extension for the siteprefs.xml?
Thank you,
3 Comments
kpritchard
Please elaborate on the solution.  Also, it may be more on the Arbortext side of things but the order of reading a Custom Directory should be looked at so that ACM/Windchill is read first rather than the Arbortext install tree.  With install tree being read before ACM/Windchill the default files that get installed with each upgrade need to be cleaned out/moved.
WindchillTeamDA
3-Visitor
We used Annonymous Arbortext Access (product idea is updated as well). This will suffice our needs.
PTCModerator
Emeritus
Status changed to: Archived
