Save-As function in Windchill should automatically point to correct content objects
0 Kudos
In article CS359569, step 2,3,4 and 5 should be eliminated, and Windchill should automatically do this when the object is copied. If you do a Save-As on a bookmap, users should not have to check out every single object in the document hierarchy, make some arbitrary change, and check it back in, just to update the invalid pointer to the original content objects.
6 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. We need more information as specified in the form you saw in the submission process. (Questions below). The more details and context you give, the better.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
AdamElkins
Here are some answers.
    • We are a software services company that has encountered this with a customer that is in the auto industry, and it has also been reported for other customers. See https://www.oberontech.com/customers/
    • I am a Senior Software Engineer
    • Windchill SIM 12.0.0.3
  3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images, or video.
    • We have customers that are creating translation packages, and they are not getting the correct content due to this issue.
    • InfoEngine is not giving us the correct document content in a document export application we wrote.
    • The problem we are asking PTC to resolve is to update the Windchill code so it points to the correct document. For some reason the Save As feature continues to reference the old document until the document is checked out, updated and checked back in.
    • Please see article above and case we had open C16204432
    • We are exporting content from Windchill using InfoEngine’s List-ContentItems webject.
    • It would save our customers a lot of time having to check out, modify, and check back in every file in the document hierarchy of DITA maps they created using the "Save As" feature.
olivierlp
Community Manager
olivierlp
Community Manager
Thank you for your idea and the information provided. Very much appreciated!
olivierlp
Community Manager
